First, the old slab needs to be removed, and the floor further excavated to accept the new thicknesses. We discovered that the original contractor actually poured foundations (!) to support the window wall. The slab was carefully cut around the exterior supports to maintain bearing.
The soil base was compacted to 95% relative compaction and 2 inches of rigid board insulation was placed on the subgrade. Rigid board was also placed on the perimeter of the room (the majority of heat loss is at the edge of the slab). The board was chamfered at the top so that no gap would exist between the wall and the floor.
Next, 2 inches of sand was placed on the rigid board. This is an extremely important component of the system, as it allows water from the concrete to be absorbed by the sand during the pour. If the concrete is poured directly on the rigid board the water has no where to go other than up, making the shake-on process very "soupy" and difficult.
Steel reinforcing is placed on the sand, and the heating pipes tied to the steel. Use a FLAT mesh, not the rolled up variety, as its important to keep the steel and piping flat.
The concrete is laid in sections, using forms. This allows the concrete contractor to properly broadcast the shake on material, and "float" the moisture to the surface (twice) applying the material after each float. Also note that the forms are kept about one inch off the sand to allow the steel to be pulled up into the concrete immediately after the pour.
During the curing process, the concrete will appear slightly mottled. Some of this will disappear as the concrete dries, and the rest will even out after the application of the sealer. We have found that L.M. Scofield's Dark Red is the best match for the original A.C. Horn Product. The wax-based sealer is a special order in that color. After the concrete has set and sealer dried we have always recommended a red wax, rather than an acrylic finish, for the final coat. Both serve as "sacrificial finishes", i.e., they protect the colored concrete from wear, but the wax results in a much more attractive finish.
