Hardy House
Hardy House
http://journaltimes.com/news/local/newl ... f887a.html
We toured the Hardy house yesterday. What a great house... and we are thankful to the new owner for his efforts and opening the house up. Fun stuff.
We toured several other houses of the same period. The contrast is startling.
Mark Hertzberg
- Contact:
Mark Hertzberg
- Contact:
Mark Hertzberg
- Contact:
Oak Park Jogger
Doesn't the gas company want to replace old meters with the small plastic units that are attached to the side of the house? More accurate, less obtrusive.
LOVED seeing the house!!!!! And can hardly wait to see it next time when even more will be done!!! Thanks for opening it, and please keep the renovation photos coming!!!!!!
Under the street side of the house, there is a sizable utility (heating) space. Based on some old photos (from Mark's book), it looks like there was grating between the side walk and the side of the house. I assume this was for loading coal or turf or whatever.
Could this space be made livable? What is the ceiling height, etc?
Also, it is not clear from any drawings. There is a room under the deck on the lake side. Can this room be accessed from the main house or do you need to walk outside?
Thank you
Thank you
Mark Hertzberg
- Contact:
I am not sure when the grating was filled in. It led to a narrow hallway (which, if I recall correctly, Wright called the "heater room") which is big enough for washer, dryer, electric box, and the toilet that I am guessing was designated for the servant's use. It is not wide enough to be livable, by any means. There are now four floor-to-ceiling columns helping stabilize the Main Street side of the house.
"Also, it is not clear from any drawings. There is a room under the deck on the lake side. Can this room be accessed from the main house or do you need to walk outside?"
The plans for this "recreation room" were drawn up in 1941 and executed after the war. It is accessed from the house...it is adjacent to the original basement area, one level below the heater room. The original east face of the dining room terrace was a stucco wall. The terrace was likely demolished and rebuilt to make this room. The stucco wall was replaced by the five floor-to-ceiling windows, and the terrace was cantilevered 3.5 feet beyond the original plane of the stucco wall. (we finally figured out how it was done a year ago)
Mark Hertzberg
Mark Hertzberg
- Contact:
