Remodeled 1911 Mullgardt threatened in San Francisco
http://news.cnet.com/8301-10797_3-57492 ... nd-desist/
Be sure to view the photo gallery.
http://maps.google.com/maps?client=safa ... CAkQ8gEwAA
Click on the Street View photo at left.
This property appears in the 1973 "Guide to Architecture in SF" (Gebhard, Winter et al, p 92). The description there may describe the original design:
House 1911; Louis Christian Mullgardt
226 Edgewood Ave.
"Edgewood is a charming brick-paved, tree-lined street with many interesting houses. The rear elevation of this one has a high battered stucco foundation surmounted by a glass gallery facing the view."
The remodel is certainly Wright-inspired, isn't it. One is reminded of the current thread(s) where confusion between Prairie and Usonian is discussed . . . !
Never heard of this house before. I really like how the high ridge roof windows of Taliesin and say Wiley are enlarged in scale and incorporated in this house.
San Francisco, such a great city. The walking paths that weave in and out of this place, any other city have anything like that?
Istanbul? Now there's a city Wright should have built something for. Would like to go someday.
This is off-topic, but, since you mention Istanbul, Robert Winter once said in a lecture that the Turkish Pavilion at the Columbian Exposition was an inspiration for Winslow:
http://www.bc.edu/bc_org/avp/cas/fnart/ ... turkey.jpg
Be careful when viewing that photo not to incorporate the fancy gable in the background into the Turkish Pavilion. There is a better photo in David Kopeny's book. It really does bear a remarkable likeness to Winslow.
As to the Mullgardt, pick your battles. Other than the fenestration, I don't see what's notable about this house as is; perhaps as it looked originally before the McMansionization it would have been worthy of a fight, but to me it just looks like a McMansionette.
Mullgardt images are rather thin on the ground, but here are a couple of houses that might explain my interest:
From "A Guide to San Francisco Architecture," 1973 ed.
From "The Buildings of Berkeley" ©1971 by Robert Bernhardi
And a bit of biographical information:
From "Building with Nature," L M Freudenheim & E Sussman, ©1974 by Peregrine Smith, Inc.
The unanswered questions about the Edgewood Ave house would be, (a) what did Mullgardt's design look like, and (b) who is responsible for the renovation, said to date from the '70s, with its unmistakble Wrightian influence (including inexplicable peek-aboo gable-end living room window) . . .
Duncan
Post by Duncan »
Mullgart's original design was basically a box in plan, with a side entrance, all deftly sited lower than the street, with a broad overhanging gently sloping Prairie roof. Window units are in the corners, opening up the rooms to the gracious site, one of the largest residential lots in San Francisco. There is redwood banding in the soffits, between windows, etc., comprising an understated Arts and Crafts, or Prairie, composition.
I was interested to see this house when it was last for sale, because the great "bird walk" a la Taliesin East is somewhat of a local landmark in the architectural community. The extension on the view side was by Eden and Eden architects, a local firm that is still extant, although not widely known. The details are very Wrightian - the sharply angled edges of the eaves, the low decks along the window wall, the redwood mullions in the windows and doors. As with the original house, the addition fits the topography brilliantly, and the landscaping is magnificent. While the original house was basically a box (in an era before most people focused on views), the addition opens to a low horizontal deck on the main floor and the perpendicular bird walk on the upper floor, with a spectacular view across a residential valley to downtown SF in the distance.
The interiors of the original house are unremarkable except for the existence of the corner windows, and the floor plan is muddled – it is clearly two different houses put together. That being said, the overall effect is gorgeous. As so often happens with great sites, they receive great buildings. Unfortunately, what also happens, is that every generation wants to build their new building on such great sites. The house and landscaping are in great maintenance, but the floor plan, arrangement of functions, and staircase need some rethinking to pull it all together as it deserves. Unfortunately, it appears this will likely not be the case.
Thanks so much for that report, Duncan. Now I have a better idea of what was there, and what has changed. It sounds like the street elevation may be mostly Mullgardt's, then ? Can I conclude from your remarks that the diagonally-banded living-room glazing is the work of the successor architects ?
Duncan
Post by Duncan »
Yes the street elevation is original and the living room is part of the addition. What is not readily apparent in the photos is that the living room window with the diagonal mullion is also articulated in plan - it is a shallow V in plan, pointing out at the point of maximum glass, with the glass meeting in a vertical beveled joint without a mullion.
Thanks. The change in tone of the interior woodwork at the joint hints at that. To your knowledge, does other Eden & Eden work exhibit this aesthetic ?
Duncan
Post by Duncan »
I have not been able to find out anything about Eden & Eden. It would be most interesting to know.
If Williams were nouveau riche smart instead of nouveau riche stupid he would purchase the site of the Morris House, tear down the ramshackle house that occupies that cliff-side site, and put his millions to good use by building the Morris House.
Which version?
