Hardest to see?
Hardest to see?
The Alpaugh thread raises a question I've never seen anyone take up explicitly: what is the hardest Wright building to see outside from public property?
Baird is in the woods, well back from the road and barricaded by thick shrubs. Bazett is up on a small bluff, far enough back from the edge to be invisible from the street. Ablin is on a heavily-planted lot, over the crest of a slope (though Wright's gate is down at street level). Lloyd Lewis is on a large wooded lot, but you could always float down the river.
- Contact:
- Contact:
Wrightgeek
The Hoffman Residence is within a gated community, and I believe that the Pearce Residence may be as well.
Since the original Charoudi Cottage is on a private island, I would think it might qualify as difficult to see?
The Lindholm Residence is not visible from the public road in front of the property. Not sure if the Lovness Estate is visible from the lake it fronts onto?
The Greenberg Residence is not visible from any public areas that I know of, and the Harold Price, Jr. Residence is also not visible from public view.
I'm sure there are more, these are just the ones I'm most familiar with. I've also not mentioned any structures that are open to the public for visits or overnight stays.
Wrightgeek
- Contact:
Wrightgeek
- Contact:
Lovness is on Wood Lake, so-called. In Minnesota, to qualify as a lake, a body of water must cover a minimum of ten acres of at least three feet depth, which makes it sound like Wood Lake should be called Wood Pond. The entire body of water is encircled by the Loveness property, which in turn is almost entirely encircled by private farm land, so access to the 'lake' requires access to the property. But I believe a view up the drive gives one a glimpse of the west end of the main house, but not the cottage.
Teater and Stromquist?
