I hadn't seen that thread on the Schwartz house.
The section detail showing the steel beams - seems to be related to an earlier version of the design and if it has any meaning its titled "Schwartz boathouse Sec Det" - which I noted is also noted on the monograph floor plan where it says Proposed pergola to boathouse and farm unit
IF section CC of the kitchen is true, then the steel beam could be incorporated into the East brickwork there with enough back span - provided the shading in the window is there to hide the steel.
This Section is also suggesting that maybe a basement was contemplated.
Interestingly no opening shown in the brick pier - does that mean the opening is only on the "heater room" side ?
I wonder if the roof is steeped as indicated
and its kinda odd that its not showing the carport roof - when clearly it ought to.
