WILLARD KELAND HOUSE FOR SALE?
Re: WILLARD KELAND HOUSE FOR SALE?
Here's a plan I found in my files - not the best, but I'm sure you'll get the general idea...[URL=https://hosting.photobucket.com/images/ ... fit=bounds]
Mark Hertzberg
- Contact:
Actually there never was a garage until the Howe addition. There was originally a carport which became a bedroom. A diagonal covered walkway then connected the garage to the new front entrance, on the other side of the pillar of the original one.
Mark Hertzberg
Thanks, John.
A delightfully generous display of images, of a house we may not see again for a long while ?
FLW Mount Pleasant, LLC. sounds a good deal more likable than "Intercoastal McMansion Development, Inc" or some such . . .! Fingers crossed.
HenryWhiting
The article says it is one of the largest Usonian houses ever built. When does a Usonian cease to be a Usonian? Or for that matter, what is a Usonian? Is it now a catch-all for all of Wright's houses after 1938 (Jacobs 1)? This may be a beautiful house, but I have a hard time seeing it as 'Usonian'.
Who knew that Wright would coin not one vague or indefinable term, but two: Organic, and Usonian. Well, the "Standard Detail Sheet for 'Usonian Type' Houses," circa 1940, defines the thing in terms of construction---but it doesn't deal with plans. I've used the term more loosely, as have others, and I don't know what limits should be set, to distinguish Usonians from other postwar Wright residences. But I would agree with those who might suggest that the term be limited to those houses that conform, at least in part, to the detailing shown on those SDS drawings---whether with flat or with pitched roofs.
Is Pauson a Usonian ? Sweeton ? Lamberson ? Palmer ? Arnold Friedman ? Griggs ? The first, third and fourth of those have board-and-sunk-batten partitions; is that enough to include them ? It should be clear that nineteen or twenty houses, from Jacobs I through M M Smith (1935 through 1946), are Usonians in the strictest sense---but not of course Fallingwater or Wingspread. What about Jacobs II, Walter, Grant, Wall, Miller, etc etc.?
Balcony level framing plan top right corner of Artstor Framing Plan Sheet 7 shows a 40'-6" long steel I-beam 10" deep.
Big beam.
Note also the large skylight behind living room fireplace over kitchen.
Intriguing house. Another one I was unaware of before.
White plaster ceilings leave something to be desired IMHO.
Would have thought this client could afford wood.
Big beam.
The red marble (?) fireplace hood at 00:36 is a bit of a surprise.
I don't think it should be taken for granted that a planked or plywood ceiling is the more desirable option in a postwar Wright house. There is quite a difference between two rooms of equal size, floor and wall material and ceiling height, with a wood ceiling versus a light-colored sand plaster one, the major difference being the amount of reflected daylight or artificial illumination in the space.
