It probably should be pointed out that except for the famous large steel beams in the living room the structure of this building is utterly and totally exposed everywhere you look.
On the thread Auldbrass Wall Sections, SDR has posted drawings showing the wall panel construction where the boards on the interior are angled in the opposite direction to the boards on the exterior. Thus the wall panels provide X-bracing to the surrounding frame. It's brilliant. I didn't realize this until after leaving. Looking at the photographs it's hard to tell if this is actually the way the house was built. I have made this mistake each time I've gone down there. I will not make that mistake again. Next time I go I'm going to make sure I know everything I possibly can about this place. Without doing that it's like going to Rome and not having a clue what you're looking at.
One thing that concerned me was observing the water from the rain approaching the bottom edges of the walls at the slab. The rain soaked the slab all the way under the eaves, but in many places, there was a dry margin of about six inches away from the wall. You can see it in the bottom shot. Hard to think that is by design. In several spots there was no dry margin, the bottom of the wood was soaking in the water.
Finally one of the highlights of the tour was a chandelier at the end of the small hall in the main house just outside the last bedroom. The docent said it was from the Pearl Palace. I don't like the Pearl Palace, but this piece was beautiful and it makes the wood glow. It's a sphere the size of a basketball, like a giant pearl, made of white frosted glass, clear-cut glass, and thin pieces of stainless steel. The lines are Wrightian of course and resemble the leaves of a closed bud before it blooms very similar to the chair backs in these shots.
