Nice section here:
https://library.artstor.org/#/asset/285 ... 9312940202
File:
https://library.artstor.org/#/search/ar ... e=1;sort=1
Davis Wig Wam House 1950
Re: Davis Wig Wam House 1950
SDR, would you take a look at the large section posted above.
I'm thinking that the large "Stanchion" is constructed similar to the truss above the living room at Staley: sandwich construction: inner frame is dashed lines and these are "trussed" by what the drawings call out as "plywood cheeks"
Do you see the same?
Yes---it appears that 2 x 12s are arranged as a bracket, than partially sandwiched between plywood "cheeks," in a way comparable to the construction of some furniture pieces at Fallingwater. A hollow or cavity is created, and the material is stepped attractively as an exterior expression.
https://library.artstor.org/#/asset/285 ... 9408566944
juankbedoya
I think this is the first time I see Davis plans. Beautiful and typical resolution. I love this kind of "teepee" houses. There are two or three amazing un-built projects of this type which are even better than the built ones.Tom wrote: ↑Wed Aug 18, 2021 2:10 pm Nice section here:
File:
