It looks as if the top sash is stationary and the bottom sash is operable as an awning unit. I believe the windows are Andersen "Flexivent" windows which, according to Andersen's website, were made from 1952 to 1979. If you Google "andersen flexivent" the first hit will be an Andersen PDF doc called "Flexivent Windows (1952 to 1979)"
that has detailed information on this type of window including sizes, head, jamb, and sill details.
The problem with standardized windows is that what you want or need is isn't always available in the size you want. The operable unit may have been what was wanted and needed, but a stationary unit having the same width may not have been available with the same height.
Duncan House
I have noticed that many of the current window manufacturers are taking ganging into consideration and making the stationary and operable windows the same size so everything matches up. Skyline Windows does this on there commercial steel windows too.
Hmm. So, it appears that Wright was stuck with the nearest size of operable sash to what would have been half of the total sash height he desired. That's too bad . . .
At least Andersen was able to make the operable and stationary parts of the window appear identical in profile -- a feat in itself. Today, I see (less expensive ?) "double-hung" sash sets in which the operable (i.e., lower) sash has a different profile, and glass size, than the stationary (upper) one. Ugh. Not a "good look" for a traditional house.
According to the chart on page four of the Flexivent PDF, the architect could choose a 20" high vent window with 14" glass, or a 24" window with 18" glass. He appears to have opted for the latter. Perhaps the former would have come closer to aligning with the 16" vertical module ?
Oddly, the same page shows Andersen casement windows. One wonders why Wright (of all people) wouldn't have chosen one of those . . .
