A detail on the Herman Mossberg house.
Goto page Previous  1, 2, 3, 4, 5
PostPosted: Mon Jul 02, 2018 9:02 am    Post subject: Reply with quote
Ridge beam over livingroom is about 44ft long.
Cannot make out the full note on the section but it's called out as 2-2x6.
Seems small to be 44ft long.
No flitch?
When did architects and builders start incorporating eave and ridge vents?
Nothing lasts forever
FLLW
PostPosted: Mon Jul 02, 2018 9:14 am    Post subject: Reply with quote
Assuming the ridge is supported at intervals -- perhaps by the rafters in many places -- its overall length is irrelevant, isn't it ?
The paired 2x6 ridge is a recurring feature of pitched-roof Usonians. Among other things it accommodates a thin roof plane, which is in turn a reflection of
Wright's habit of minimizing the size of structural members, perhaps another aspect of an economy that "pays for" a generous roof area, and which is
effectively disguised by his prominent fascia trim.
The occasional appearance of a plaster ceiling plane which is radiused at the ridge -- an unfortunate anomaly, as I see it -- may be explained by a builder's
insistence on a deeper ridge beam. At least, I have imagined that as the reason . . .
PostPosted: Mon Jul 02, 2018 9:26 am    Post subject: Reply with quote
Usually ridge supports rafters and elimiates rotation at the connection.
If the rafters of the living room on the garden side are continuous through to the flat roof then they are trussed -
... then it does appear they could possibly support the ridge.
Otherwise the length of the ridge seems like it would bend in the middle
... looking again at the section
I think that's it.
those gardenside rafters support the roof
very cool
FLLW
PostPosted: Mon Jul 02, 2018 9:35 am    Post subject: Reply with quote
Schaberg:
A ceiling like this one would be impossible to decorate with trim parallel to the rafters -- like Mossberg and many others. Here's a case where
the span, and the length of the rafters (?), might have demanded a heftier ridge beam . . . ?
PostPosted: Mon Jul 02, 2018 9:51 am    Post subject: Reply with quote
... or perhaps a collar tie.
at Kentuck Knob I think there is something like
a dropped ceiling plane .
FLLW
PostPosted: Mon Jul 02, 2018 11:31 am    Post subject: Reply with quote
To be clear, a wood member at a ridge behaves as a beam when there are no collar ties or attic/ceiling joists present to restrain the outward thrust of the rafters. No moment connections present at the rafters' connection to the ridge and plate will allow deflection of the structure in plan and section.
The slow progressive failure of the Sweeton living room roof was in part the product of a double 2x6 ridge with excessive span and a lack of rigid connections of the rafters to their bearing points. Steel flitches in the ridge and every 3rd rafter, moment connections, and halving the effective span of the ridge, solved the issues of the primary roof. The double cantilever at the corner of the house was another matter.
See the pics at this page:
http://wrightchat.savewright.org/viewtopic.php?t=7523&postdays=0&postorder=asc&highlight=sweeton&start=135&sid=f95f8d770204c3e96f7548122f947d9e
PostPosted: Mon Jul 02, 2018 11:55 am    Post subject: Reply with quote
Succinctly stated
FLLW
PostPosted: Mon Jul 02, 2018 12:56 pm    Post subject: Reply with quote
The rational architect seeks details that work -- for him -- and, once found, applies them repeatedly, while looking for ways to improve them. This is precisely how Nature does it . .
I wonder if the Livingroom "trussed rafter section" occurs elsewhere?
FLLW
Page 5 of 5
