"Folly House" by John Howe
Royston is a great little composition...I have been in communication with the current owner of the Royston Cottage for a few years. He has a full set of Howe's drawings and is doing his best to be faithful to the original design intent and built conditions of the Cottage and Howe's 1974 gallery addition.
All of the built-in furniture has been retained for restoration. Most of the moveable furniture and some built-ins were in fact made by George Nakashima under a commission from the Roystons. All of the Nakashima pieces were removed and sold by Mrs. Royston's estate in 2010 prior to the sale of the Cottage.
https://www.bidsquare.com/online-auctio ... et-1152792
To my knowledge, the uphill development is not related to the Royston Cottage, nor is it the work of the cottage's owner.
Daniel Dominique Watts
John Howe - Royston vs. Inwood
Post by Daniel Dominique Watts »
Yes SDR, I wrote 2 comments on that page you sent link for.
I did visual comparison contract in my notes as well. The Royston "base home" w/out artist studio added onto it is basically the INWOOD plan enlarged a bit and "flipped" as you enter bedroom up steps on opposite side (see plans on page you linked) and the bedroom plan as well flipped. Honestly the Inwood plan is really really intimate and feels fantastic.
I do believe it is built on the same site that Wright had built a small home for his Aunt Nell (cabin) that I did research on. Wright finally was able to purchase the site in early 1950s and as he said finally able to tear it down.
It was built /designed by Wright when he was working with Silsbee at Spring Green prior to going to Chicago. Done around same time as the School for his Aunt Nell & her sister & the Chapel.
The kitchen & "bar" wall separating kitchen from living room is almost identical. A 3/4 ht. wall is for part of it with high shelf at top of wall and lower countertop. This is where the silver, glasswear, french wine bottles were all stored inside of Royston home. I took 2 photos inside & 2 from outside glass windows. Only the fireplace at INWOOD more rustic stone vs. the refined 3"-4" thick flagstone stacked at Royston against thin CMU block internal walls. Howe used CMU block construction inside walls with veneer of stone w/airspace outside on wall & thin 1"x2" slats on inside of block wall to add plywood veneers to for inside finished walls. This was able to be seen inside the open Bedroom wardrobe closet thru windows as well. The exterior construction of wall cavity I photographed as 1 veneer stone had fallen out of the prow end of LR patio wall on east side of it. I took 2 or 3 photos of it at time.
While Royston a bit larger as you can see, the LR feels like it could hold over 40-50 people in it with being comfortable. Has built-in corner unit to south of the fireplace against outer wall. Fireplace is as well scaled larger than at Inwood. I do prefer rustic fireplace at Inwood & scale of the Royston bedroom/bathroom and kitchen/bar area. Both are great homes.
I was under the impression that Inwood was constructed on land the Howe’s acquired from Wes Peters. I was unaware of a cabin for Aunt Nell designed by young Frank... Please share with us what you’ve learned about it. Are there any extant photos or drawings? The site is visible when looking out from Taliesin....was Wright wanting to remove an early and unsightly (to him) bit of his canon as he had with the early Hillside Home School Building?
