Raking the horizonal brick mortor in FLW houses
Larry Weinstein
Guest
PostPosted: Mon Feb 07, 2005 8:01 pm    Post subject: Raking the horizonal brick mortor in FLW houses Reply with quote
I would like to rake the horizontal mortor in the brick walls and fireplace on a house I am building. My bricklayer says it's a bad idea since water can collect and crack the mortor. Anyone had experience with this problem. (I live in Ohio.)
KevinW
PostPosted: Tue Feb 08, 2005 12:18 am    Post subject: Reply with quote
Larry
I agree with your mason. Using a raked joint on an exterior application is not recommended, and could void any warranty. My suggestion would be to use either a "v-joint" or a "weathered joint". Either of these will shed water, and still offer the horizontal shadow you are wanting.
I will keep looking though, to see if any new technology is available that I am unaware of.
Guest
PostPosted: Tue Feb 08, 2005 9:59 am    Post subject: Reply with quote
I am wondering how the Dream House is coming along. I know that you have been working on the project for some time now. I was looking to build the house myself and bought the plans. We decised not to build due to extreme cost overuns.
I would be very interested in hearing how far along you are?
Guest
PostPosted: Tue Feb 08, 2005 3:04 pm    Post subject: Reply with quote
Your bricklayer's prediction came true at Robie and Martin. You might contact the responsible organizations (the FLlW Preservation Trust and SUNY Buffalo respectively) to ask if they ever found a solution.
Peter
usonian1
PostPosted: Tue Feb 08, 2005 3:48 pm    Post subject: Mortar raking Reply with quote
Larry:
Although I would tend to listen to your mason, I can understand your desire for this feature.
I wouldn't put too much stock in the example made of the Darwin Martin Complex mortar treatment. Although the mortar in the horizontal is DEEPLY raked (the vertical joints are flush mortared for futher emphasis of the horizontal), to the best of my knowledge, there were no premature failures of the joints. Keep in mind that this house is nearly 100 years old and does have numerous masonry issues, mainly due to neglect over time.
Considering the environmental similarities to Ohio, it probably wouldn't hurt to research the current plan for the Darwin Martin restoration. I'm sure that this issue has come up! The restoration architect is Hamilton, Houston & Lownie based here in Buffalo. Good Luck!
Greg Brewer
Guest
PostPosted: Tue Feb 08, 2005 5:34 pm    Post subject: Reply with quote
Regarding the Robie House, research has shown that contrary to popular belief, horizontal mortar joints were not raked but concave tooled. This technique has been replicated as part of the exterior restoration.
Larry Weinstein
Guest
PostPosted: Wed Feb 09, 2005 9:38 am    Post subject: Raking the horizontal mortar Reply with quote
Thank you for your advice. I would be interested in seeing what is being done with the mortar at the Robie house if anyone has a photograph showing a brick detail. I've looked at the Wright medical building in Kettering and that does have a deep rake in the brick mortar.
Regarding the LMDH we're building...we're under roof finally. Interior framing is complete. We'll be installing the cypress siding over the next two weeks, weather permitting. Plumbing, HVAC, and electric are being installed at the moment. Anyone interested in the plan is certainly welcome to contact me at larry.weinstein@wright.edu.
tsutton
Guest
PostPosted: Tue Feb 22, 2005 9:20 pm    Post subject: raked joints Reply with quote
Here is the story:
If you want the horizontal look for your brickwork you must rake the joints. Also it is assumed you have a generous overhang say about four feet. The water never reaches the joints and therefor there are no worries about failure. The chimney is a differeft matter. Do not rake the joints in the chimney or any other masonty projecting above the roof. Inside raking the joints of the chimney and other masonry is bound to collect dust, but then do you want the horizontal look or a self cleaning house. Just buy a shop vac and clean the brick joints and joints between concrete slabs.
Tim
