Need an arch. to design my house
Mobius
Post by Mobius »
Mr. Sutton - congratulations on your Usonian. You must be very proud, and very happy with how your design has come out. Truly, you will be reaping the rewards of such a design, and "in spades" I might add. Well done.
Kim, perhaps you might consider selecting one of FLWs Usonian designs, and gently "massaging" it to achieve a plan which will suit you. I am in the process of building a modified Usonia #1 (Jacobs1, 1936) and you can see what I've done at http://4sure.co.nz/nzonia ("nzonia" is a play on FLWs Usonia, the abbreviation for New Zealand, and the fact that NZ has often been referred to as "Godzone" or "God's own" country.)
Frank built over 50 usonians, and while many are similar, the styles (L-shaped vs Inline) vary substantially. There are even 2-story Usonians, and after the war, when skilled labour became expensive, Frank created the "Automatic Usonian" which relied on less labour in the field, and used Concrete Blocks (albeit, custom built ones) for the majority of the structural elements.
I think, you will find a design of his which you can modify to your own purposes, without destroying the features, outlook and aspect the originals had. To my way of thinking, even a modified Usonian is still going to be better than anything an architect of today could create for you.
In any case, having a very strong sense of what you want is the best bet: and if you can find a design which you like, the refining process becomes much shorter, and you are more likely to achieve success.
Good luck!
Collinst3
Mike Rust
Post by Collinst3 »
Mike Rust--former head of Residentail Design for Taliesin (left several years ago because he was fed up) designed our wright-inspired home and does business all over the US. Our home is in Ohio and Mike works in Arizona.
His website is www.rust-architect.com. Our home is at the top of the home page and in the gallery under Collins home.
Good luck.
Tony Collins
___________
FLW addiction recently fed by building a wright-inspired ranch designed by former senior Taliesin Fellow.
Guest
Collins Home
Post by Guest »
Mr. Collins, you have a beautiful home. One can certainly see FLW influences at work here. Mission accomplished!
Pdean
Dallas, TX.
