Guggenheim museum
Luc Cazanave
Guggenheim museum
Post by Luc Cazanave »
where the ducts for ventilation, heating and air-conditioning in the Guggenheim Museum run? the cut-outs do not reveal any false ceilings and on the plans there is practically no technical vertical circulation.
Re: Guggenheim museum
Luc, we recently discovered Taliesin drawings of Wright projects online. I've called up the Guggenheim file; perhaps among these 792 images will be found the answer to your question ? Unfortunately the drawings are collected in no consistent order:
https://library.artstor.org/#/search/gu ... =1;size=48
"As a former copy editor, I always feel I am defending the person whose name is being misspelled, not attacking the person who misspells it." Ronald Alan McCrea (1943-2019)
Image 7 is a plan of the basement lecture room; at the top of the drawing are a large machinery room and two rooms labeled "air conditioning." This of course does not answer your question---but it suggests where in the building vertical chases might originate.
17
18
19
23
35
44
45
62
127
154
167
299
322
327
360
414
422
432
488
503
511
538
579
609
612
655
659
684
721
725
726 (specifications)
731
743
753
When I lived in NYC, I often went to Guggenheim in all seasons. The interior was always perfectly comfortable, so however the heat and A/C were delivered, it was efficient. There is a large element that is perfectly vertical, not ramped, that contains elevators, stairs and such. That would be the obvious place. Of course, you must be certain you are looking at as-built plans; over the 17-year period it took to make the thing, a lot of drawings and alterations were made.
Last edited by Roderick Grant on Sun Jan 10, 2021 3:29 pm, edited 1 time in total.
Yes. All the drawings have a 1943 project number; the latest drawing I saw was dated 10/59, a revision of the sprinkler system in the carpentry shop . . .
Starting at image # 717, the project number changes to 4727.
The last few dozen images are drawings for the annex to the building, at the southeast corner of the lot.
The Artstor image numbers listed above are ones containing elements of the HVAC systems.
These are the two isometric views in the collection showing parts of the HVAC system.
Image 4305.276
Image 4305.378
This drawing for the brass or bronze plaque set into the pavement in front of the entrance to the museum is one of a half-dozen such designs, sprinkled at random throughout Artstor's Guggenheim file. This one is marked there "use this." The variations consist mostly of different inspiring mottos; a couple of them include the exhortation to "respect the masterpiece."
Does anyone read Greek ?
These two drawings for the cornerstone remind us that Mr Wright wished to honor the contractor of his masterpiece. The anomaly that catches my eye is the italicized N. Another drawing shows a few letters, including this one, at large scale; the N is slanted there as well. I can't imagine what could have inspired this oddity . . .
The Greek says "Aristophanes". The Quotations Page says the quote is from The Wasps.
Heh-heh. Thanks, Reidy. I should have screen-grabbed the other plaque designs when I passed them.
I'd gladly put the Guggenheim drawing images in some kind of order, if Artstor would be interested in having volunteer help.
So, from the iso drawings it appears that major supply ducts are formed into the concrete and spiral with the ramp. It was a great question to ask. Never occurred to me.
Yes. There are a couple of plan drawings in which a hot-air duct is shown circling around a ramp, starting at the supply end and tapering perfectly evenly from a broad width to a narrow point, c. 330 degrees later, with registers placed periodically along the way.
Luc Cazanave
Thank you for all these proposed tracks that I will explore carefully.
After examining the plans in my possession I was well considering a circuit of this kind.
But when I consider the complexity and the importance of these networks in our contemporary (inorganic?) constructions, problems that are almost always solved in the same way (false ceilings and gigantic false floors), I am particularly interested in the solutions of the organic way.
I didn't notice indication of how the ducts in the Y-shaped ramp slabs taper (as shown in plan). I assume the diagonal bottom "leaf" of the slab construction is structural, and would therefor presumably not want to diminish in size just to provide an increasingly constricted triangular opening . . .
