Mid-Century Structure?
Matt2
PostPosted: Fri Jan 25, 2019 9:41 pm    Post subject: Mid-Century Structure? Reply with quote
I'm researching mid-century architecture and the use of exposed structure. Think of Neutra's spider legs. Is there any great wisdom out there on the origins of such structural tricks? Why they were in vogue from '45-55? And what benefits they provided to a design? (One drawback was that wooden beams exposed to rain eventually rotted).
PostPosted: Fri Jan 25, 2019 11:15 pm    Post subject: Reply with quote
Well, to clear up that little tidbit, methods abound for prolonging the life of exterior building elements. Projecting rafter tails, popular in Craftsman work, for instance,
can be given top-side cladding of copper or other material; see Greene & Greene for some impressive examples. I believe you'll see the comparable detail in Neutra.
Exposed structure has the benefit of a very long history, if nothing else. Not the sort of thing one associates with Baroque architecture, or with the American balloon-framed residence -- or with Wright, by and
large -- but the international Art and Crafts, followed by the European Constructivists (think Rietveld, for instance), found the primal joy inherent in structure-as-decor, as aesthetic and functional raison-d'etre.
The constructivist movement has recurring episodes; Cliff May's post-and-beam houses, followed by the more suave Eichlers and such avant-gardists as Ray Kappe
(his own home in Brentwood, first and foremost) are just a few of many examples of bare-bones architecture in the last century. I recently read that Mies liked to think
that he was dealing with the "skeleton" of the building . . .
Matt2
PostPosted: Fri Jan 25, 2019 11:22 pm    Post subject: Reply with quote
Yes, preservation often involves metal or dutiful application of new stain or paint on a regular basis. And there's the fact that most mid-century houses probably weren't intended to last beyond 50 years.
The most obvious ancient precedent is the flying buttress...if you can call that ancient. But where did Nuetra's spider legs come from? Was he the first of the last century? And was the purpose behind them to...what?...free up a corner for more glass maybe?
PostPosted: Sat Jan 26, 2019 12:21 am    Post subject: Reply with quote
Yes -- I read it as wanting to eliminate the prosaic corner post. Wright was perfectly happy with "normal" structure in his earlier career -- what more, or less, would you
have, than a row of openings divided by structural (or non-structural) posts, with the simple and direct meeting of two such planes at right angles at an identical post ?
And what is different, there, from the the Greek temple, where all columns are identical (along with, typically, the spaces between them) -- including the corner one ?
That temple is the first self-conscious expression of the post and beam structure. It is a very short trip from Greek temple to Case Study post-and-beam residence.
It is the stylist, the latent constructivist, the romantic modernist who is moved by the cantilever and the open corner. Wright's choice was to pretend that the corner
doesn't exist, that the architectural fabric, whether wood, brick, stone or glass, can simply fold, at a ninety- or a sixty- or a hundred-and-twenty degree angle, and march
on its merry way, corner post be damned . . .
PostPosted: Sat Jan 26, 2019 10:12 am    Post subject: Reply with quote
The spider leg plays Wright’s game but turns it inside out. Wright brings the final post in from the corner, and cantilevers the roof. Neutra moves the post beyond the corner, extending the house into the garden, allowing a massive corner window. I must say, Neutra’s solution truly makes the corner seem to disappear, at least when seen from the interior, much more so than Wright’s.
https://goo.gl/images/nDvRGt
Gerrit Rietveld toyed with the idea earlier at the Shroder house:
https://en.wikipedia.org/wiki/Rietveld_Schr%C3%B6der_House
Within the context of modern architecture, it’s possible to attribute this innovation to Neutra. Post and beam was never Wright’s thing.
Matt2
PostPosted: Sat Jan 26, 2019 11:50 am    Post subject: Reply with quote
Thanks so much to both of your. Really clears away the fog for me. Never thought of that inversion of Wright's internal supports that result in a corner cantilever, with Nuetra reversing that. I'll pull some Nuetra books off the shelf and see when he did this first.
PostPosted: Sat Jan 26, 2019 11:55 am    Post subject: Reply with quote
FLW's one venture into a sort-of spider leg - which I call outrigger - was at Evans, where hefty piers are placed beyond the porch and porte cochere, connected by long beams supporting the roof structures. It's a more grandiose approach, but accomplishes the same thing.
As for exposed wood, a few of the 11th century Stave Churches of Norway (Borgund, Gol og Heddal, e.g.) have survived. Most that haven't, burned.
PostPosted: Sat Jan 26, 2019 12:01 pm    Post subject: Reply with quote
I haven't looked at those; I assume that the structural members are protected in one way or another. In the modern all-wood building, shingles or other renewable surfaces do that job.
I would be interested to know when Neutra first showed his spider-leg. Didn't I recently see a house with two of them ?
Evans: http://www.prairieschooltraveler.com/html/il/chicago/wright/evans3.jpg (stone cladding not original)
plan © W A Storrer
Matt2
PostPosted: Sat Jan 26, 2019 8:36 pm    Post subject: Reply with quote
Hines' book on Nuetra has a photo of the "Earl Street Reunion House" of 1949 with classic spider leg or outrigger supports (page 208). There is a sort-of spider leg in the Kelton apartments of 1942 but it doubles as the support of a trellis. The Kaufmann House of '46 has external supports, but they appear to be more conventional columns that don't have that distinctive turn from horizontal to vertical.
PostPosted: Sat Jan 26, 2019 8:58 pm    Post subject: Reply with quote
Kelton:
https://i.pinimg.com/originals/b3/57/34/b35734b5ee52267811c806b8654b7cdb.jpg
The Chuey house of 1956 appears to have two of the supports:
https://www.laconservancy.org/locations/chuey-residence
Matt2
PostPosted: Sat Jan 26, 2019 9:41 pm    Post subject: Reply with quote
An interesting detail about the outriggers on the Perkins House of 1955 is that the vertical support seems to be notched so that the outer side continues up to cover the end of the horizontal. It's an important detail to help convey the "turn" from horizontal to vertical. The same effect could have been done with a miter corner, but that would have been a lot less structurally sound.
PostPosted: Sat Jan 26, 2019 10:35 pm    Post subject: Reply with quote
Good find. I think we'll see several means of making that corner, in Neutra, over time ?
Coincidentally, that same joint appears in this delicious mystery from pp 76-77 of "NorCalMod," Pierluigi Serraino, Chronicle Books, 2006.
PostPosted: Sat Jan 26, 2019 11:02 pm    Post subject: Reply with quote
. . . or straightened, to make the verticals plumb. Takes away that extra little bit of drama . . .
If the Rosenbaum Picture is of a wooden UFO, this cabin might be the shuttle or landing pod.
Anyone have anything on this opus ? A plan would be nice. I'm thinking we see both corners
of the living room, in the two photos . . . so, twin triangular decks ?
PostPosted: Sun Jan 27, 2019 2:07 pm    Post subject: Reply with quote
Not positvie but pretty sure I've never heard of the Evans house before.
... corners of main block like UnityT.
Nothing lasts forever
FLLW
PostPosted: Sun Jan 27, 2019 3:16 pm    Post subject: Reply with quote
It isn't one that comes up much. The differing bays on the two floors -- three square windows below, four above -- amuses me.
