Auldbrass Plantation
MOman2
PostPosted: Thu Sep 13, 2018 2:23 pm    Post subject: Auldbrass Plantation Reply with quote
Comments on how hurricane Florence will or will not affect Auldbrass Plantation?
PostPosted: Thu Sep 13, 2018 6:04 pm    Post subject: Reply with quote
There are a lot of trees on the property so the potential via wind damage exists. Also, there is a body of water behind the home. I'm not certain if flood damage from there would be a possibility. But, given that the storm may dump enormous quantities of rain, I would imagine that couldn't be ruled out.
SREcklund
PostPosted: Thu Sep 13, 2018 6:34 pm    Post subject: Reply with quote
They don't call it the Lowcountry region for nothing, and the latest predictions show the storm stalling and heading further south - pretty much guaranteeing Auldbrass will see massive amounts of water. One of the members over at the Wright Attitude has said he will be in contact with Scott the plantation manager after the storm passes; I'll pass along whatever I learn.
PostPosted: Fri Sep 14, 2018 9:33 am    Post subject: Reply with quote
The southern-most tip of S. Carolina, where Auldbrass is located, is at the very edge of the storm. Greenville, in the direct path, might be in greater danger, unless it's too far inland.
