Ennis on the market
Goto page Previous  1, 2, 3  Next
PostPosted: Fri Jun 29, 2018 6:17 pm    Post subject: Reply with quote
A point worth noting is that the horizontals in the Ennis corner windows were to be on an 8-inch module (two per block) rather than 16 as at Freeman. See the 3rd and 5th drawings in SDR's post of Friday the 29th, 2:07pm.
When he used a photo of Ennis in In the Nature of Materials, Wright penciled in the bars (at 16 inches).
PostPosted: Fri Jun 29, 2018 7:24 pm    Post subject: Reply with quote
Aha -- good one. They even appear in the small-scale section drawing at top of post.
And, the same dining-room section drawing shows the exceptional patterned sash, which stand out on the sash schedule sheet, in their proper orientation
and placement.
An oddity is the patterned closet doors, perhaps with vent holes worked into the square decoration, and the stretching of those squares vertically, on another
and taller closet door -- as if drawn on rubber, or subjected to digital manipulation of the simplest kind.
(My copy of In the Nature of Materials, plates 257-8, does not seem to include a touched-up Ennis photo. I'd love to see that . . .)
PostPosted: Sat Jun 30, 2018 12:04 am    Post subject: Reply with quote
How embarrassing. I meant to say In the Cause of Architecture: the Meaning of Materials, but now I can't find it there either, in the Rizzoli Collected Writings. Must have been some other edition.
One of the touched-up photos is on p. 127 of Terry Patterson's Frank Lloyd Wright and the Meaning of Materials.
PostPosted: Sat Jun 30, 2018 8:49 am    Post subject: Reply with quote
cajunfan
PostPosted: Sat Jun 30, 2018 10:29 am    Post subject: Reply with quote
I have a question: does anyone know what (if anything) is located on the first/ground floor of the Ennis? Meaning, I know there is a small entry, which takes you up to main floor of the house, but is there amything else on that ground floor? Like at the Robie house, and it's billard/playroom? Is there a floor plan out there for this ground floor? All I ever see are plans for the main floor and chauffeur's quarters. Thanks in advance.....
Matt
PostPosted: Sat Jun 30, 2018 10:52 am    Post subject: Reply with quote
Are there any covenants attached to the sale? Does the buyer have to maintain the house as is? I'd hate to see some billionaire tear it down.
PostPosted: Sat Jun 30, 2018 11:26 am    Post subject: Reply with quote
The main feature of the ground floor is (you guessed it) a billiards room, shown in the photos earlier in the thread looking NW toward the entry hall. It was originally unfinished storage, which Wright finished for the Nesbitts in the early 40s, adding the fireplace. You'll notice that it contains no patterned blocks. The S side, not visible in the photo, is mostly glass doors. They are the only glass that has the horizontal mullions as designed.
There is also a powder room at the bottom of the stairwell, N side of the entry, and a laundry room on the S side of the entry, just W of the billiards room.
PostPosted: Sat Jun 30, 2018 11:27 am    Post subject: Reply with quote
Note that in the living and dining rooms, boards form the ceiling, the canted walls are blocks, and the battens run across both the ceiling and block walls to make a connection. See the longitudinal section of the dining room above. SDR, the ceiling in Mabel's room was designed to be flat. No detail of it has been published, so I don't know the material.
The transoms in Freeman were originally redwood, and were replaced by Lautner with aluminum in the 70s when they failed. The plans do not show the blocks at the corners, which may have been added to make the connection more secure. When I first saw Freeman, the aluminum was unpainted, and practically vanished in the sunlight. Later they were painted an unflattering shade of brown one might come across on an unkempt public sidewalk.
The patterned closet doors are almost as designed, with no vent. Solid teak.
Cajun, in Mono 4/237 is a partial plan of the entry level at the base of the stairs. The powder room in that plan was moved west, and where the PR is shown is a closet. The entry vestibule is under the pantry, and is quite roomy. (There is a glimpse through the pool room door in the Curbed photos.) Although enclosed, the vestibule was intended to be an open porch, with the entry doors (double glass) at the east end, opening onto a transverse hall, under the service hall, with the stair up at the north end, and access to the pool room at the south. To the right, under the guest room, is a laundry. The pool room is under the dining room. The space below the house from living room to master bedroom is an unfinished area with a dirt floor, about 4 to 5 feet in head height.
PostPosted: Sat Jun 30, 2018 11:33 am    Post subject: Reply with quote
cajunman, this note on W A Storrer's plan drawing should answer your question . . .
cajunfan
PostPosted: Sat Jun 30, 2018 11:46 am    Post subject: Reply with quote
Thanks! And so sorry I didn't see the pics on the first page....don't know how I missed that!
PostPosted: Sat Jun 30, 2018 3:47 pm    Post subject: Reply with quote
A couple of other Ennis changes show up in the present drawings and photos. The first of the longitudinal sections, looking south, shows the hallway five blocks tall, not six as the Curbed photos show.
The first of the detail drawings has a view captioned N side of D.R.. The parapet is three blocks high, with openings two blocks high. The Curbed hallway photo is from the other side of that parapet. It's only one block off the dining room floor, showing in the photo as a recessed block course with a four-block opening above it.
That would have made the parapet 6'8" high on the hall side. Reaching the top of the stairs, we wouldn't have seen into the dining room. The Sijistan / Nesbitt drawing, from about the same perspective, seems to show shelving in the openings with rugs draped from them, blocking the view from the hall. I suspect he hated that worm's-eye view of the dining room that we get now.
PostPosted: Sun Jul 01, 2018 12:22 pm    Post subject: Reply with quote
Reidy, the longitudinal drawing doesn't show the passage to the hall. That 5-block doorway is to the living room. The hallway, or loggia, was always planned to be 6 blocks high. At the point where the loggia spans the gap between Mr. and Mrs. Ennis's bedrooms, the doorways onto the small terrace on the west side was supposed to be one block lower than on the east side.
The fenestration enclosing the dining room from the loggia ought to be built. You're right about that, FLW would not have liked that glimpse from the entry loggia into the dining room.
Another place where blocks are missing is between the dining room and living room, and the dining room corner windows, which should be two blocks high, not one.
Meisolus
PostPosted: Wed Jul 11, 2018 9:41 pm    Post subject: Reply with quote
Regarding the windows in the Ennis House, Julie L. Sloan discusses the original designs in her wonderful book "Light Screens: The Complete Leaded Glass Windows of Frank Lloyd Wright". She notes that "the main windows of the living areas were executed in a different leaded pattern than the one designed for it. The executed design features an inverted variaion of a pattern that was later sketched in the windows of the elevations for the A.M. Johnson Shrine project."
Here is the shrine:
Regarding the windows in the library, according to Sloan they are not by Wright. They are nearly identical to windows in the Sedgwick Brinsmaid house in Des Moines, IA which was designed by Arthur Heun. The windows may have been designed by George Mann Niedecken and made by Giannini and Hilgart. They may have been the manufacturer for the windows at the Ennis House, which would explain their presence.
Am I correct in saying that the big window in the living room would have had a huge plate glass center and the sides would have had horizontal mullions?
PostPosted: Wed Jul 11, 2018 10:26 pm    Post subject: Reply with quote
You show the A M Johnson project -- for those who have not seen it in detail.
Roderick or Stan can answer your questions better than I can. But, to your last query, no, I don't think that's the right description of the living room
view window. It's actually a pair of French doors surrounded by glass, and one of the most consistently rendered elements in the house, if these six
images are to be credited.
The side-lights I think are shown on the sash sheet, just to the right of the closet door with medallions. The doors are top row, just left of center. The
rule for unframed glass is, "set directly into concrete grooves with horizontal sash bars only." Despite the dictum noted on the sash sheet, the transom
glass above those doors appears to be single-pane in all of these illustrations.
PostPosted: Thu Jul 12, 2018 11:10 am    Post subject: Reply with quote
The major alteration of the living room window/door arrangement is the inclusion of block mullions separating the 12-block, 16' transom window into three parts. The block frame of the doors rise to transom level, turn away from the doors, over the side lights, thence surround the transom window, in a pattern as old as Minoa. Perhaps the additional blocks were installed for fear of that 16' span, but they shouldn't be there. The transom over the doors was to be plain blocks of only one unit deep, while the surround was to be two blocks deep and patterned.
(Who was it asking about a first floor plan? There is one complete in Sweeney's book on page 85.)
Page 2 of 3
