House for E Clarke Arnold, Columbus, WI, 1954
Goto page Previous  1, 2, 3  Next
PostPosted: Wed Jul 04, 2018 6:32 pm    Post subject: Reply with quote
Aguar has a dedicated section critical of the 30/60 in Wright's work.
Nothing lasts forever
FLLW
PostPosted: Wed Jul 04, 2018 7:06 pm    Post subject: Reply with quote
Aguar ? Remind me . . .
PostPosted: Wed Jul 04, 2018 7:10 pm    Post subject: Reply with quote
Wrightscapes
by the Aguar's
History of Wright's work through lnadscape perspective
educational and informative
FLLW
PostPosted: Wed Jul 04, 2018 8:42 pm    Post subject: Reply with quote
Ah, yes. Well, I'd better add that to the library. I've just made more room here for books, by getting rid of my ancient KLH 17s and using the space for more shelves . . .
And my Taschen volumes now each has a shelf to itself, for easier access and longer life.
Happy Fourth !
PostPosted: Thu Jul 05, 2018 9:50 am    Post subject: Reply with quote
Tom wrote:
One of these days I may own the Tasch Vols.
Only construction shots I've ever seen of Bazett are found in Sargent.
Sargent does not have the series of construction shots I'm thinking about regarding Bazett.
They are in some book somewhere though.
FLLW
PostPosted: Thu Jul 05, 2018 11:38 am    Post subject: Reply with quote
Tom, I recall seeing drawings of Bazett, as well, but I cannot find them. The bit of information that seems to have been published in only one source is in the Gebhard/Zimmerman book, "Romanza," which includes the plan of the guest wing added by Franke, the second owner (page 44).
The thinness of the roofs and trusses suggest the entire thing was built of 2x4s.
PostPosted: Thu Jul 05, 2018 1:15 pm    Post subject: Reply with quote
1939 Bazett plan:
"Romanza" plan:
PostPosted: Thu Jul 05, 2018 1:18 pm    Post subject: Reply with quote
I'm not seeing the trusses you're talking about . . .
photos © Simon Clay
photo © Esther Born
PostPosted: Thu Jul 05, 2018 4:00 pm    Post subject: Reply with quote
Where the sloped ceiling meets the flat ceiling -
I think there is a steel beam along that line from masonry to masonry
at "line of soffit"
The construction shots I am thinking about show it
... according to memory
Still looking for those shots
In any case, I would think the "honeycomb" glass walls provide
greater resistance against the roof forces.
Great drawings and photographs by the way ...
Thanks SDR
I see no indication of trusses either.
But the support of that roof is amazing
FLLW
PostPosted: Thu Jul 05, 2018 4:25 pm    Post subject: Reply with quote
Yes. It's almost as if the glass planes that are largely perpendicular to the ridge and eaves are taking thrust loads from the roof, in the way that flying
buttresses do -- and we know that ain't it. If the rafters are 2x4s or 2x6s, there could be custom flat steel angles bolted to them at the joints that would
help make the roof retain its shape . . . I suppose.
PostPosted: Thu Jul 05, 2018 4:31 pm    Post subject: Reply with quote
But don't you think the glass Frames must be taking some of that load?
... got to be.
FLLW
PostPosted: Thu Jul 05, 2018 4:51 pm    Post subject: Reply with quote
Wright loved showing off his ability to eliminate the need for collar ties. It would be best to think of the flat roof and eaves over the glass bays as "horizontal beams" that tie together the two ends of the living room. The eaves act as structural components in the same way as buttresses, but at 90 degrees to the vertical plane of the wall. Smith house in Jefferson has similar framing.
PostPosted: Thu Jul 05, 2018 5:47 pm    Post subject: Reply with quote
Thanks, John. That's the "neglected aspect" of roof structure that's easy for me to forget. It would be fully operable only to the extent that the roof was a stable plane -- sheathed with plywood, for instance ? I suppose that was common practice for Wright, starting . . . when ? When did plywood come online as a building material ?
Heh-heh -- I wonder if some of that lovely plywood on the ceiling is more than decorative: heavier than 1/4", and/or nailed and glued in place . . .
PostPosted: Thu Jul 05, 2018 6:25 pm    Post subject: Reply with quote
I wonder if one of the attractions of a low-pitched roof, for Wright, whether hipped, gabled or shed, was that it would tend to produce less diagonal thrust . . .
I still marvel at the memory of the video interview with Brandoch Peters, who remarked that his father had admitted at one point that he couldn't always
prove with numbers the validity of a certain structural solution he'd specified. He just knew it would work. That video was presented here, some years back.
Sounds like my way of working: seat-of-the-pants engineering. Of course, I work at the scale of furniture . . . !
edit: sp of Brandoch
PostPosted: Fri Jul 06, 2018 11:07 am    Post subject: Reply with quote
Found the construction shots of Bazett:
Masterworks
BBP
170-171
"Building the Usonian House"
Long steel beam clearly shown spanning length of living room.
FLLW
Page 2 of 3
