House for E Clarke Arnold, Columbus, WI, 1954
Goto page 1, 2, 3  Next
PostPosted: Thu Jun 21, 2018 3:59 pm    Post subject: House for E Clarke Arnold, Columbus, WI, 1954 Reply with quote
We sometimes comment on Wright's recycling of a Usonian plan for a second client. In this case, the precursor was an unbuilt house for Robert Bush, in Palo Alto, CA, designed in 1950. As it turned out, the
"clone" was altered before construction, into a new and unique variation of the original plan.
The Bush project:
The initial plan for E Clarke Arnold:
And the built plan:
© 1993 by William Allin Storrer
photo © Juergen Nogai
Master bedroom:
Guest bedroom:
photo © Dave Anderson
Color images except as noted: © 2009 by TASCHEN GmbH and by the Frank Lloyd Wright Foundation
Black-and-white images: © 1988 A.D.A EDITA Tokyo Co., Ltd. and by the Frank Lloyd Wright Foundation
PostPosted: Fri Jun 22, 2018 9:37 am    Post subject: Reply with quote
I never tire of looking at the drawings or photos of the Bush/Arnold/Thaxton plan type, or commenting how much I like it.
The high perforated board windows in a stone wall seen in the Dave Anderson photo of the guest room lead me to believe that room is within the TAA/John Howe addition. It also appears that the gallery wall of the original house was designed to be wood framed with board and batten siding, but per the Mono pic it was built of stone.
Great house, in a nice little town with a LHS jewel box bank to boot, still held by its original client's family.
PostPosted: Fri Jun 22, 2018 11:12 am    Post subject: Reply with quote
DNR, I believe you are right. That stone-walled bedroom has a closet perpendicular to the wall, which doesn't exist in the original bedroom wing.
I bet the change from horizontal B&B to stone in the gallery was a FLW alteration. At the right end of that same elevation is the vertical wood screen; the two wood elements would have clashed.
PostPosted: Fri Jun 22, 2018 6:15 pm    Post subject: Reply with quote
The Arthur Mathews Usonian of 1950 has a wooden screen reminiscent of those seen in Futagawa's exterior photo of Arnold, above (though these screens
don't seem to appear on the plan). In the Mathews house the screen divides the entry and central gallery from the kitchen; it has boards cut and placed at
60º from its faces just as these do, in keeping with the 30-60 nature of the planning grid.
That house also features rows of small windows placed at regular intervals in its masonry exterior walls, a detail seen here as well.
I wish we had a drawing to show how the elbow of the plan, between kitchen and central bath, was modified by Howe/TAA to permit entry to the new bedroom
gallery. There are minor differences between Storrer's plan (above) and the Taliesin sheet, including in the kitchen. Storrer in most cases shows what he found
at each built Wright property.
Anderson's undated photo of the guest room appears to show a dark stain to the woodwork, while Nogai's 2008 photo shows unstained wood in the master
bedroom. So far, the former is the only photo we have of the house perf -- though wth the dark stain it is difficult to read the design. (I wonder how many enlarged
Usonians have examples of reproduced "extra" perfs.)
HOJO
PostPosted: Sat Jun 23, 2018 4:53 am    Post subject: Reply with quote
Both stone wall and closet are parallel to a side of the triangular light in the ceiling, so the closet is not perpendicular to the wall.
PostPosted: Sat Jun 23, 2018 9:41 am    Post subject: Reply with quote
Good catch, HOJO. Closets separating bedrooms is good for acoustic privacy . . .
PostPosted: Sat Jun 23, 2018 12:42 pm    Post subject: Reply with quote
HOJO, you are right. The closet seems to be perpendicular, and the light is not that much of a gauge, but the bed, which is obviously perpendicular to the wall is not parallel to the closet, as can be seen by the closet hinges.
PostPosted: Mon Jul 02, 2018 6:20 pm    Post subject: Reply with quote
Found this searching for a Cedar Rock thread.
Never seen this house before - at least those first exterior perspectives.
But consider the structural section through the Mossberg Living Room
in relation to the section through the Arnold's Living Room.
Both cases: flat roof intersecting with pitched roof, stabilized by trussed rafters.
In Mossberg the truss is concealed and above the flat roof.
In Arnold the truss is exposed and below the flat roof.
... makes me want to take another look at Bazzett
Nothing lasts forever
FLLW
PostPosted: Mon Jul 02, 2018 6:28 pm    Post subject: Reply with quote
Bazett
FLLW
HOJO
PostPosted: Tue Jul 03, 2018 10:27 am    Post subject: Reply with quote
And at the other side of the living room there is also a truss, above the flat roof.
PostPosted: Tue Jul 03, 2018 11:55 am    Post subject: Reply with quote
HOJO: do you know where that truss falls online in the plan?
FLLW
HOJO
PostPosted: Tue Jul 03, 2018 1:51 pm    Post subject: Reply with quote
triangle trusses between horizontal ceiling plane, sloping roof plane and vertical part above windows.
PostPosted: Tue Jul 03, 2018 3:53 pm    Post subject: Reply with quote
Tom, about Bazett: In Mono 6/160, there is no indication of a truss to hold up the pitched roof over the living room. As built, in Tasch 2/381 there are thin, wide trusses on either side. No drawings to show what's going on inside them, however.
PostPosted: Wed Jul 04, 2018 9:24 am    Post subject: Reply with quote
One of these days I may own the Tasch Vols.
Only construction shots I've ever seen of Bazett are found in Sargent.
I think I remember seeing them place a steel beam along the line where the
slope roof and the flat roof meet - from one end of the living room to the other
... long ways.
That would contain some of the pitched roof thrust ...
but not all ..?
Concerning the beautiful color renderings of the Bush Project above.
Makes me wonder if he didn't begin by laying one big equilateral triangle down and then starting from there.
FLLW
PostPosted: Wed Jul 04, 2018 6:28 pm    Post subject: Reply with quote
Well, he might have -- though I think most students of the man would suggest otherwise, as that's just a bit too arbitrary for a serious contextual environmentalist, even if a formalist . . . ?
Either way, no drafting table I've seen has sported a 60-60-60 triangle. But the 30-60-90 drafter's triangle is a universal staple. And it's hard to look at the Maginel Barney, McCartney
or Howard Anthony plans without seeing one of those staring you in the face . . . !
Page 1 of 3
