Article: Restoring the Dana House - Springfield, IL
PostPosted: Thu Apr 12, 2018 9:41 am    Post subject: Article: Restoring the Dana House - Springfield, IL Reply with quote
Restoring the Dana-Thomas House
Meisolus
PostPosted: Fri Apr 13, 2018 8:08 am    Post subject: Reply with quote
The article mentions a gate at the front door that was removed in 1910. Does anyone have a picture of it in situ?
PostPosted: Fri Apr 13, 2018 9:53 am    Post subject: Reply with quote
Undated photos in standard works:
Manson, p 122
Hanks, p 78
PostPosted: Fri Apr 13, 2018 10:57 am    Post subject: Reply with quote
Two images from Monograph 1 (the house is listed under 1901). No drawings in that reference show an entrance gate; perhaps one of the later volumes -- sketches and studies -- will show the gates.
PostPosted: Fri Apr 13, 2018 11:02 am    Post subject: Reply with quote
Photo in the Bramhall "Ausgefuhrte Bauten." No photos there show the gates closed.
PostPosted: Fri Apr 13, 2018 11:39 am    Post subject: Reply with quote
I'd suggest that the gates were a client request, perhaps post-construction, which the architect had not anticipated and which displeased him. That would perhaps explain their absence in published photos and drawings . . . ?
PostPosted: Fri Apr 13, 2018 11:53 am    Post subject: Reply with quote
"In the Cause of Architecture" was published in the March 1908 issue of The Architectural Record (pp 155-221), 3 years before Ausge.
On page 175 is a view from the same vantage point as the above, but, because the vines are significantly shorter, taken earlier.
There is no sign of the gates, proving that they were a later addition, some time between 1908 and before the 1911 publication of Ausge, probably 1910.
But since the photo with the gates in place was used in Ausge, it would appear that FLW had no problem with them, or he would have used the earlier shot with the vines not quite so overwhelming.
PostPosted: Fri Apr 13, 2018 1:27 pm    Post subject: Reply with quote
Or, perhaps he liked the foliage, and was willing to use the photo(s) as long as the gates were shown opened, thus virtually invisible ? There are seven
exterior photos of the house in the book; in five of them the entrance is visible. Of those, only the one above, and another from the same vantage that
includes more of the facade, show the gates in place.
One of the photos, on page 34, might have been retouched to eliminate the gates; in that photo the ivy (?) is less plentiful.
Thanks for the dates -- that's useful.
HOJO
PostPosted: Fri Apr 13, 2018 4:29 pm    Post subject: Reply with quote
In the above Ausge-picture it looks like the gates were removed and only the suspension construction remains.
The length of the shed shadow under the suspension construction is not long enough.
What I don't see in the Ausge-picture is this gate:
https://www.flickr.com/photos/zaruka/32999049604/in/photolist-Sh1KM7-SYz5Hq-Tywiep-T9s5ME-Rp3UUg-Rp3S4r-S4cLMf-Rp3Pdr-RmrXmd-PJzCTD-LgHkCJ-LgHi71-LH6wkX-LxwGRU-KLchKg-LH5ua6-KKZYjm-LgEV4C-KKZ3rw-KKZ36G-LH3Tyz-LxsDF3-LxsALA-LA2C8z-LE2aw9-LgAfAy-KKViZn-LDQ693-LDPTA3-KZUQrw-KC8w8c-JoNCur-Ka4JYy-Ka4HnC-Ka4GPJ-HBfpDk-J7kNDT-JdWiLk-JdWixz-JdWi4P-JaWPqj-HhQufb-JdWhjc-JdWgTn-JaWMy3-JdWgnT-Fve1Ej-DVkam8-DVk8Dk-CXPDMq
Meisolus
PostPosted: Fri Apr 13, 2018 4:54 pm    Post subject: Reply with quote
The gate was curious to me because it looks like it was basically right up against the door. It doesn't seem very practical. But I love the fact that Wright would do gates from time to time in a similar manner. There is one at the Burton Westcott House in Springfield, OH. It had been removed and was reproduced during the restoration. To me, this one makes more sense as it does somewhat enclose a space, instead of butting right up against the door. Still, it would be nice to see a photo with the gate closed. I'm curious how it relates design wise to the rest of the building.
PostPosted: Fri Apr 13, 2018 7:36 pm    Post subject: Reply with quote
Good work, guys. The gate(s) in the Flickr image do seem to occupy the correct near-square rectangle . . .
As for what appears in the Dana photo, those hook shapes, top and bottom, read perfectly as the pintles upon which the gates would be hung. But their
shadows also indicate that they -- the mounting frames -- project beyond the face of the surrounding masonry -- which it seems to me is most un-Wright.
Is there any other use of a similar decorative texture in this commission ? The corner blocks to the gates do resemble those on the iconic double-pedestal
table lantern in the house.
