Mid-century Modern Usonian
Macrodex
Post by Macrodex »
Reminds me of the Trier/Usonian Exhibition House in plan.
I wonder what do those second floor windows in the chimney mass illuminate?
Nice exterior massing.
That's an odd window, since it doesn't show in the interior view of the fireplace. This is obviously a project that may not have been thought through entirely.
Where did this come from, Macrodex ? Is it a plan book ? I see a number 1809 . . .
Macrodex
Post by Macrodex »
Just from some Flickr account I was perusing.
DB222
Post by DB222 »
It looks like that window in question allows light into the kitchen via the hallway labeled "laundry." The placement of the kitchen in the center of the building inspired this decision, I'm sure. It seems well thought out to me.
There are two sets of windows above the main roofline, in that masonry mass; one seems to be an extension of the entry window-door element. If those openings (above and below) are in the same plane, then the second-level masonry wall to the left of that stacked opening is placed not above the rear wall of the living room but floating over the carport space. Quite odd. Perhaps the viewpoint of the entry-side perspective places those openings in alignment accidentally, and the upper-level window is actually set back at the living-room wall (near the numeral 3), with the opening coincident with the passage into the living room.
If all this is so, then it may be that the clerestory element shown in the interior view is vertically exaggerated on the exterior -- for unknown reasons -- so that it appears almost as a second level to the house ? And the interior perspective omits the wall in the foreground which separates the living room from the carport . . .
DB222
Post by DB222 »
I think the narrow upper window actually aligns with the passage into the living room and the wall from which it juts is the vertical continuation of the LR/carport wall.
I'm tempted to load this picture into SketchUp and use its photo matching feature to generate a quick and dirty model...
Do it !
I find McDonald to be superior in terms of originality and composition to many of the better-known Wrightians who have practiced in the last half-century. While the plan here is hardly unique, the composition and the details are convincing, at a first look . . .
DB222
Post by DB222 »
Well, no luck. I guess the function doesn't work on 2-point drawings...
