Unbuilt Wright Plan
Unbuilt Wright Plan
Ok, THIS TIME, this is a plan that truly isn't documented in Taschen. It's for the Alpaugh's -- I'm assuming the same client. There's a tiny elevation to the right with some weird shapes above. Odd roof...
No drawings like this one appear in Taschen under the Alpaugh listing; I don't have the relevant Monograph.
Macrodex, will you remind us whether you have previously presented a similar sheet for our perusal -- or was a similar drawing presented here by another reader ? I recall the plan, but not the typical Usoninan wall section at upper left.
The small chair elevations are reminiscent of other Wright chairs, I believe -- I'll look for them. As to the building plan and elevation, I really don't know what we're seeing, here . . .
Well, I can't blame anyone else; I posted a drawing set including this sheet, a couple of years ago. See page one:
http://savewright.org/wright_chat/viewtopic.php?t=4879
Neither the plan nor elevation strike me as the work of FLW. I'm inclined to believe it was done by an apprentice in FLW's name, possibly for an additional structure added during a late stage. No space for it is included in the blueprint of the lot (image 1).
Note that it is a 30/60 grid, whereas the rest of the place is confined to a square grid with 45 degree offshoots. FLW would not have done that. It would have been dissonant.
Good work. Roderick, do you see anything in the other drawings of the Alpaugh set which isn't consistent with the built project ? I ask because the display lettering on the subject drawing is distinctive and is consistent with the remaining sheets, in that particular. (The drafter could possibly be identified by the lettering . . .) I agree that the plan and elevation are not likely to be Wright's work.
