Plans for Taliesin floor lamp?
jmixon
Post by jmixon »
http://www.room100.nl/designer/miscellaneous/taliesin
Can't find anyone who actually sells these plans, are they online at this point? I'd buy them if I could, but I can't find them! I am trying to build some with my father for my parents house and we need dimensions.
lang
Post by lang »
try this site: www.prairiedesigns.com . Good luck.
You could try and see if you can find a copy of "Woodworking Plans for a Hillside Table Lamp" somewhere online (though, that may not be an easy task).
jmixon
Post by jmixon »
DavidC wrote:You could try and see if you can find a copy of "Woodworking Plans for a Hillside Table Lamp" somewhere online (though, that may not be an easy task).
Yeah I been looking. Can't find it.
I'll check the above site though.
KevinW
Post by KevinW »
I own a floor lamp that Bob Beharka made for his own home, I could give you some dimensions if you would like. There are several pictures of it here...
http://www.flickr.com/photos/75562383@N ... 528521766/
While the light box's, etc..dimensions would be faithful, Bob took some creative liberties to the top.
KevinW
Jjen
Table lamp
Post by Jjen »
Hello, I have the book"Woodworking Plans for a Hillside Table Lamp" if you would like to borrow it. Email me if you are interested.
Based on the dimensions of the Taliesin-approved Yamagiwa copies, the basic dimensions of the 5-light table lamp in millimetres are (roughly):
Overall height: 750
Post: 30x30x730, 30x30 cube at top articulated by 10 groove 5 deep
Base: 210x210x20 thick, including (felt?) pad (The lamp is not centered on the base, but the dimensions for its placement are not included. Best guess: post is 40 from two sides of base.)
Light boxes: 70wx60hx145, + 45x30 notches, inside of notch aligned with edge of post; back of box, 15 beyond post. Wood 10(?) thick; 5(?) thick wood wrapped around post at notched opening.
Boxes: 120 apart on center.
Reflectors: 160x110x5, 10 beyond post, 120 center to center; bottom reflector, 60 from center line to top of base.
Structure at base: 80x57.5x10(?) board supports bottom reflector; perpendicular to this, pieces of indeterminate length extending from center post. At the back an oddly shaped board 30 wide extends the larger board 'through' the post, extending upward to the center line of the second reflector, with a 10x18(?) notch centered between the bottom reflector and base, and a 10x60 notch coincident to the first light box.
The reflectors are edged with 5 wood, with the bulk of the piece made of a slightly thinner material lighter in color.
I suspect the originals were measured in English units. In the process of translating them into Metric, the dimensions may have been fudged somewhat. But it doesn't matter that much. What matters most is the relative measurements. To translate into English, all you would need is a single multiplier for each dimension.
KevinW
Post by KevinW »
The example above has the horizontal reflector on top of the light box, shouldn't they be below the light box? Unless it's the pendant version, which is quite different...those have the reflector shade on top.
KevinW
Seems the location of the reflector could be in either position depending on the use of the light. I doubt the lamps much good for task lighting; can they be used for reading? More about setting a mood.
KevinW
Post by KevinW »
Task lighting, not so much...but to gently and beautifully illuminate a small area, indeed. Yes, the reflector can go in either location, I was just mentioning in terms of faithfullness to original design, perhaps.
KevinW
But was the 'original design' meant to be just one fixed idea? Weren't there always differences? The number of lights? Floor, table or ceiling, or even pole lamp, as the photo above indicates? I think the design was merely a template for a wide variety of designs. No purity of intent here.
KevinW
Post by KevinW »
I don't know what intentions Wright had. Sure, everything can be changed....that whole spice of life thang.
KevinW
